Which linux version?
I just installed Linux Mint cinnamon on my laptop. In the download area I see that there are 2 variants,I don’t know which one to use as I am totally new to Linux.
Most likely:
Linux 64bit Installer
qcad-3.32.5-pro-linux-qt5.14-x86_64.run
Linux 64bit
Intel/64bit
Installer
(Recommended)
Version: 3.32.5
Please refer also to:
I use Linux Mint and always use qcad-x.xx.x-pro-linux-qt5.14-x86_64.run as Andrew suggests, I’ve never had a problem.
Thanks for the answers. I did not know that I had to make the file executable!
You’ll find that happens quite often, I always check that the execute permission is set with new software.
