[solved] Exception occurred. Entity NOT saved:
Hallo ich kann keine texte mehr speichern!
Versions
QCAD version: 3.19.1.0
Date: Nov 11 2017
Qt version: 5.6.2
Compiler version: Clang 6.0.0
Build Date: Nov 11 2017
Revision: 7cb021aef11c8ce056574d3b415ee66c7c96e10d
Architecture: x86_64
OS: macOS
OS version: macOS 10.13
Was ist da los?
DANKE für die rasche hilfe
Hi I can not save any Text in a drawing! not even in a new one. Allways the exception occured if you save it…
Tanks for helping
Regards Theo Stauffer
What is the exact text you are trying to create (contents, fonts, size, etc.)?
Hi it does not depends what vou type…
Bretter
Arial 40 Kursiv
source:
\fArial|b0|i0|c0|p0;Bretter
Kommando: new
Kommando: text
Kommando: save
Exception occurred. Entity NOT saved: 38
Zeichnung gespeichert: /Users/ts/Desktop/Parcours-Pläne/test2.dxf
Format: R27 [2013] DXF Drawing [Teigha] (*.dxf)
Do you use a drawing as default template when starting a new drawing?
Edit > Application Preferences > File > Templates > Default Template
No
Unfortunately, this is not reproducible here. Can you save your file as follows and attach it to your post:
  • File > New
  • Add text
  • File > Save As…
  • Change “Format” at the bottom to “R15 [2000/LT2000] DXF Drawing [dxflib] (*.dxf)”
OK here is the file
test.dxf (190 KB)
Exception occurred. Entity NOT saved: 1ea
Zeichnung gespeichert: /Users/ts/Downloads/test.dxf
Format: R15 [2000/LT2000] DXF Drawing [Teigha] (*.dxf)
Sorry
Speichere mit Dateiformat Version 'R15 [2000/LT2000] DXF Drawing [dxflib] (.dxf)'.
Schwarze Objekte und Layer werden als weiss gespeichert.
Benutzerdefinierte Farben werden auf die nächste verfügbare Farbe ‘gerundet’.
Zeichnung gespeichert: /Users/ts/Downloads/test2.dxf
Format: R15 [2000/LT2000] DXF Drawing [dxflib] (
.dxf)
test2.dxf (27.8 KB)
if I open the test.dxf no text is in it
if I open the test2.dxf text is in it!!!
Format library ? Teigha problem?
with format dxflib it works..
Thanks. I can reproduce the problem now. Please change the line spacing in the text dialog to a value of 4 or under. The DXF standard only allows values up to 4 and Teigha enforces this rule in the latest version which is unfortunate. I will look into ways to allow QCAD to work around that unnecessary limitation.
Great, thanks for your help. I tried a lot of settings… but this one not…
Regards Theo
