New to the full version of QCAD. Any suggestions or ideas as to how to delete individual nodes? I recently purchased a tree DXF, but it came through as a three part panel drawing, so what I would like to do is delete the individual panel lines, and join the three panels as to wind up with an individual drawing that I would like to cut (CNC plasma) on a single sheet. This DXF is readily avail on eBay, Pintrest, etc. 29.pdf (52.4 KB)
If the panel boundaries are line entities, removing them is merely by selecting and ‘Delete’.
If they are part of a polyline one can use Break Out Manual (B2) and two clickpoints.
Or Divide (DI) (cutting) and remove what is obsolete.
For joining the panels I see some overlapping shapes …
