January 30, 2025, 6:43am
3
@Fe6
Schau mal in Qcad unter
Menü, Datei, Neu von Vorlage nach-da gibt es bereits viele verschiedene Vorlagen (Templates).
Ansonsten gibt es auch noch viele im Forum als EU Format …
ISO eng. A3 metric template
Hi Guys
I have slightly modified the QCAD ISO eng. A3 metric template.
In the attached dxf file you will find that I have added a Notes section and have enclosed the border. As well as creating ‘editable’ blocks out of the Notes, Revision and Title blocks which will show up in the block list. You can simply edit these to suit your needs (‘double-click’ to open the block in its own window -then you can change it).
I have also added AEC layers, again which will show…
oder auch als US Format …
Hi guys - if you are in need of a couple “Imperial drawing sheet templates” - here we are
[Husky-2013.07.28-05.png]
Well organized imperial Drawing sheets incl. Pr-defined Layers and Blocks for:
Paper Frame,
Title Block incl. Projection symbol 3rd angle (US),
Zoned Border (Sub-Block of Paper Frame),
Logo / Name (Sub-Block of Title Block - changeable!),
Drawing unit: inch
Linear Dimensions:
Dimension height: 1/8" (0.125 inch),
Format: Fractional, Precision: 1/32"
Scal…
