I think you’d be hard pressed to find a teacher anywhere in the world who would consider LLM output as a legitimate homework submission, but I digress since the QCAD forum doesn’t have a rule against not doing your homework before posting. Lucky you. It should. For the record, doing your homework in this context would mean that you know Javascript already; have read through all of the QCAD API programming tutorials; got at least a bare minimum development environment set up so you could edit the code and see the edit’s effect in QCAD; searched through the forum to find threads similar in scope to what you’re looking for; and at least tried to solve it yourself.
So you didn’t slowly push CVH’s script away from the thread subject in the direction of xref functionality? You also did all of what I said above before posting? Also, your thread is currently unsolved. Anyone viewing your thread now and in the future won’t get any practical information as to a “Script to read block name, copy name and enter as text”. If you are indeed “not a “taker””, you might want to make a detailed post to help anyone who views this thread. Needing this to be explained is a bad sign though… ![]()
I don’t know either! I know he means well and it is coming from a good place but he hurt everyone involved responding this way. He hurt himself by communicating his time isn’t worth anything. Hell, I have a laundry list of scripts I’m working on. If it is free, I can keep him busy. He hurt me because if it is free then that means my time spent learning the QCAD API was a waste of time. Not to mention having to waste my time on worthless back and forth about how my comment applies to a knowledgeable coder coding something in private. He hurt the community because, as of this post, anyone who reads through this thread will be wasting their time and not even get an answer by the time they reach the end and also because it is free for you and not for them and his time could’ve been spent working on QCAD itself. And, last but not least, he hurt you because a “Script to read block name, copy name and enter as text” is the perfect first script for someone to try to write. That opportunity is now lost for you. ![]()
If you’ve sent PMs to him through the course of him writing this script for you, then you have both private and professional communication with him. You’re striking me as the kind of person who says one thing while doing something different. ![]()
This seems like a goofy comparison to try to make while you’re coding things in private and when the script CVH wrote for you is still being kept private.
I’m assuming this is in response to my suggestion that CVH bill you for his time? You don’t charge for your time working on other people’s projects? If it’s not all about money then that means you’re doing CAD work for free for people, right?
