# Hatch problems
**URL:** <http://forum.qcad.org/t/hatch-problems/4912>\
**Category:** QCAD Troubleshooting and Problems\
**Created:** [October 31, 2019, 12:37pm UTC](http://forum.qcad.org/t/hatch-problems/4912 "2019-10-31T12:37:29Z")\
**Posts on this page:** 1\
**Showing post:** 3
<div class="post-metadata">
**Author:** ![CVH](http://forum.qcad.org/letter_avatar_proxy/v4/letter/c/82dd89/32.png) [@CVH](http://forum.qcad.org/u/CVH)\
**Post date:** [November 1, 2019, 2:07am UTC](http://forum.qcad.org/t/hatch-problems/4912/3 "2019-11-01T02:07:42Z")
</div>
That was a hard one.
Hatches are defined as:
```plaintext
; remarks and blank lines are ignored
*pattern-name[, description]
angle, x-origin, y-origin, delta-x, delta-y [, dash1, dash2] [, dash3] [, dash4] [, dash5] [, dash6]
angle, ...
Empty line
The name start with \*, max 31 characters long.
A line is max 80 characters long, max 6 dashes.
Positive dashes define the lenght that is ON.
Negative dashes define the lenght that is OFF.
Zero dashes are dots.
Nothing wrong with the patterns \*AR-SAND or \*DOTS so far.
Did some hatching in different units and with different scales.
It turns out that dots are always rendered as line pieces 0.02 units long.
An this regardless the unit or the scale.
With the aplied scale of 0.0008 the first dashed line off \*AR-SAND becomes:
… 0, -0.0309, 0, -0.0345, 0, -0.0330
Its obvious that the dot spacings are the same magnitude as the rendered dots.
Instead of a dotted line it rather looks like a dashed line.
Workaround:
Included is the metric pattern \*AR-SAND2 without dots.
Changed the dots to 0.01 ON what is scaled properly.
Copy the file to …\QCAD\patterns\metric.
Reboot Qcad, change pattern.
[ar-sand2.pat](http://forum.qcad.org/uploads/short-url/j2RE5Lr8hWmOkaNMblCcbLfVLE8.pat) (295 Bytes)
_[View the full topic](http://forum.qcad.org/t/hatch-problems/4912)._
