What I mean is that Arcs don’t have ending points as a property/atribute/menber:
- QCAD: RArc Class Reference
See member documentation starting at:
Like Lines do:
- QCAD: RLine Class Reference
Meaning that any endpoint of an RLine (or a polyline node for that matter) has a well defined X/Y position in the plane.
While the endpoints of an Arc is a mathematical result, the closest definable X/Y position.
getStartPoint(): qcad/src/core/math/RArc.cpp at master · qcad/qcad · GitHub
getEndPoint(): qcad/src/core/math/RArc.cpp at master · qcad/qcad · GitHub
getPointAtAngle(a): qcad/src/core/math/RArc.cpp at master · qcad/qcad · GitHub
It will be rather precise near the origin, near (0,0;0,0), but decreases in accuracy when further off because of the limited number system.
Polar to Cartesian use trigonometry, RArc to bulge or reverse uses tan()/atan().
The distance between two points is by the hypotenuse what uses sqrt().
Internally rads are used and the accuracy for PI is great but limited.
It matters but that is not the sole or main issue here.
Matching an RLine start point is within 1e-6 in all directions.
Matching an RArc end is within 1e-9 rads and the amount of 1 radius away from the center within +/-1e-9
=> The tolerance for an RArc endpoint grows with the radius.
And to avoid issues I have seen the use of tolerances up to 1e-3 in standard resources.
It might be a fix in most cases but in the end tolerances should be relative to how accurate it can be.
As example:
RPolyline.appendShape() and all that rely on this: qcad/src/core/math/RPolyline.cpp at master · qcad/qcad · GitHub
When joining an RArc to an RPolyline :
- The RArc start point if verified against the last node.
- If the match is within 1e-3 then the RArc endpoint is the new ending node.
- The bulging factor is calculated of the RArc … As is.
The issue is now that it is uncertain if the distance between the nodes equals the originally chord …
… but the bulge is calculated from the original sweep and the bulging factor is an exponential value.
It is thus possible to construct a polyline where the intersection of 2 neighboring Arc-segments doesn’t match with the node in between.
And when you then expect the node to be the intersection then … ![]()
